Computer Aided Design
Subject: Re: Sculpting CAD CAM
Sculpting CAD CAM
1/3/24
Greg Frater
I am looking for software solutions for developing sculpted surfaces such as family crests from 2D images. By sculpted, I mean organically shaped elements, not just 2D extrusions with bevels or softened edges. I currently use Solidworks (2010) and have a small CNC router. I have experimented with Blender and various solutions that start with SVG format files, but Blender seems to fill a different function. I can get SVGs into Solidworks, but the sculpting capability is lacking. Any ideas? Part of the problem is sorting through all the potential solutions, while another part is utilising my familiarity with the Solidworks environment and its power for scaling and manipulating models for CAM outputs.
1/3/24       #3: Sculpting CAD CAM ...
David Wishengrad Member
HI Greg,
If you know enough of the basics then going to cnc can be archived with most anything laying around from a 3d model.
I know Jim Falk knows how to sculpt using Autocad. I saw a few models of his that were over the top. I really don't have that level of skill myself. You should do a video search with scupting with acad or better yet, bricscad.
Rhino may be a good option for you too. Good to do video search with this too.
Once you find what works for you, you can then just process it in almost any decent cnc software for the toolpaths.
You are trying to do what I call "design build". Autodesk had a white paper out years back where they said design build was designing the formulas to create the parametric models. I don't think they could have had it more wrong. :(
BTW, decent dental software has some very nice sculpting tools. You may want to look into that also. There is probably some free stuff around to play with.
1/3/24       #4: Sculpting CAD CAM ...
Greg Frater
Thanks Dave. Yeah getting to toolpaths isn't a problem. I use MeshCAM which is quite adequate once I have an STL file. Rhino would probably work as it suits jewellers, but I've never tried it. It's a bit of a pity not to be able to get there with SolidWorks which cost 13k back in the 90s when I first bought it. Speed of operation is a concern - if it takes 8hrs of CAD work before I even start on wood it would be uneconomic. I'll follow up on any suggestions.
1/4/24       #5: Sculpting CAD CAM ...
Ian
actually, vcarve or aspire are great for this, and they have a ton of 2.5 d templates in the library that comes with it.
1/13/24       #6: Sculpting CAD CAM ...
The MW Studio Sponsor - The Millwork Studio
Website: themillworkstudio.com
Your quest for the ideal software for crafting those beautifully sculpted family crests is totally relatable! It's like diving into a sea of options, and finding the perfect fit can be a real challenge.
Now, considering your Solidworks background, have you checked out Rhino? It's got some serious street cred for its prowess in surface modeling, and it might just be the missing link you're looking for. Sure, it has a bit of a learning curve, but the payoff could be huge in terms of creating those organic shapes.
And let's not forget Fusion 360. It's like the Swiss Army knife of CAD software – blending parametric and sculpting tools seamlessly. Plus, the fact that it plays nice with CAM outputs is a definite win for your CNC router adventures.
I totally get the struggle of sifting through options. Maybe give a couple of demos a spin? Sometimes, it's all about that hands-on experience to see which one vibes with your workflow.
1/16/24       #7: Sculpting CAD CAM ...
Rufus Cooke  Member
Website: shorelineparametrics.com
Hi Greg.
I feel your pain. I'm a longtime Solidworks who about 14 years ago had to model corinthian column capitals for CNC and have avoided organic shapes since and I think alot of other parametric modelers have steered clear as well.
My problem is that I like SW for all sorts of things though and if it's similar for you, maybe SW 3D Sculptor? I don't know about cost or compatibility with 2010 however (I'm using 2020).
If it were me, I'd probably take a punt with SW and go right to VCarve or Aspire.
Cheers,
Rufus
1/31/24       #8: Sculpting CAD CAM ...
savannah
You can consider Meshmixer which primarily focuses on mesh editing, it still offers basic sculpting tools and integrates seamlessly with Solidworks, allowing you to transfer your sculpted details.
    • ECabinet Systems
    • CabMaster Software
    • The Millwork Studio
