Computer Aided Design
Subject: Re: Busellato AutoCAD 2008
2/12/25
Rick Member
We have an old Busellato CNC (1999) that needs AutoCAD 2008. Does anyone have any resources for this version, or a good "work-around"?
2/12/25       #2: Busellato AutoCAD 2008 ...
Dan Member
As for and AutoCad 2008 solution your options may be quite limited.
I imagine you need AutoCad to create the layered dxf file for your Busellato. I forget the name of the software that Busellato uses.
Though, even if you find a version of AutoCad 2008 there are additional issues. Chances are that AutoCad 2008 will not run on a modern computer. As the program may be 32-bit and will not run on a 64-bit computer. Also, most new computers run Windows 10 or 11, I am not certain AtuoCad 2008 will run on Windows. An add-on program that runs on 32-bit will not run on a 64-bit version of AutoCad, unless programmed to do so. The last issue, is whether AutoDesk even allows AutoCad 2008 to be registered and activated.
Best of luck.
2/27/25       #4: Busellato AutoCAD 2008 ...
Brent Wilkerson
You should be able to use any version of AutoCAD. Would just need to save the DWG or DXF file back to an older version. (See attached JPG)
View higher quality, full size image (569 X 257)
2/27/25       #5: Busellato AutoCAD 2008 ...
Rick Member
The problem we're having is we were using Autolink to communicate with the old Busellato and the Autocad 2008 had a "tool palette" tab for setting tool parameters, both of which are gone in 2025.
2/27/25       #6: Busellato AutoCAD 2008 ...
Brent Wilkerson
Contact either Busellato, Delmac (Which I think they merged with SCM), Casadei Busellato or AutoResearch directly.
You'll need to reinstall it.
http://www.autocutresearch.com/AutoLink.htm
service@casadeibusellato.com
Or maybe try contacting these people???
https://jklmachinery.us/pages/busellato-software-upgrade
2/28/25       #7: Busellato AutoCAD 2008 ...
DWishengrad
I think your choices are really centered around what it is you do and other software that you use.
It would seem to me that you don't need Autolink to write to that machine. There are many others CNC programs that will do that.
Just because the previous software worked, does not make it the best choice for what it is you do.
In the meantime, being as we don't know all that you are doing, check out Enroute. It's a cheap solution for some. If you are laying your dxf files by hand you make your own pallet to assign layers to geometry and process them with that for your gcode.
    • The Millwork Studio
    • ECabinet Systems
    • CabMaster Software
