Computer Aided Design
Subject: Re: BIM helpful for structural engineers
10/25/16
Ava Smith Member
Website: http://www.bluentcad.com
Hi all, a quick question is on my mind. Is BIM helpful for structural engineers? Please help me to understand.
11/1/16       #2: BIM helpful for structural engineer ...
Martin Flaherty  Member
Website: skooter.com
Good morning Ava.
I'm a little confused by your question after looking at your site. However, my initial answer to your question is "yes" and "no". "Yes" because when used properly the metadata associated with BIM objects and the corresponding software you're using on a team that's using QTO functions, developing the spec' accordingly (etc), it can be incredibly helpful. "No" when there are gaps in the above and when it's not needed based on the scale of the project and how quickly the project is moving.
That's a bit of a generalized answer but it's a bit of a general question. Sorry if it doesn't help.
m
11/2/16       #3: BIM helpful for structural engineer ...
Ava Smith Member
Thanks Martin Flaherty for your reply.
Actually I am looking for detail description related to BIM involvement in structural engineers and your reply confuses me. If you explain me in detail.
Thank again..
11/2/16       #4: BIM helpful for structural engineer ...
david wishengrad
It sounds like a good idea, and sure people use it, but allowing an engineer to decide what to buy is not usually how it works.
The way it is usually done, they specify what the values need to be, given a loads and variances. Quite often the people responsible for building a structure know a better/cheaper/lighter way to accomplish the calculated requirements. Sure, there are valid reasons for BIM, but my opinion to how it deployed through software, with the intention of forced constraints and parametric assemblies with proprietary technology leads to new real world problems that that far out-weight the benefits, as currently deployed. The issues with inter-interoperability within a CAD environment that pop up are many. They usually present themselves as proxy entities that cannot be edited and/or printed without an additional and unneeded purchase. The people using it do not even bother to learn how to properly export the data (sometimes as simple autocadout) and the mess of problems continues.
11/4/16       #5: BIM helpful for structural engineer ...
Well put David. The only "positive" story out there of note about BIM at this level is the Gehry hospital in SF. It's one of the most visible and promoted uses of BIM at this level and can showcase the whole "IPD" concept as well. However, if you can talk to any of the folks at contractor or engineering practitioners on the project, they will all tell you some horror story. Conceptually it's a good idea. The practical application and real world factors still have BIM at this level more theoretical than actual.
6/19/25       #7: BIM helpful for structural engineer ...
Sydney Mendes  Member
Website: https://www.aeodc.com/
Thanks for your question! Absolutely, BIM is incredibly helpful for structural engineers. At AEODC, our BIM services enable structural engineers to create precise 3D models that improve design accuracy, detect clashes early, and enhance collaboration across all project teams. This not only saves time but also reduces costly errors during construction.
    • The Millwork Studio
    • ECabinet Systems
    • CabMaster Software
