Computer Aided Design
Subject: Re: Microvellum XML Files
7/22/25
James
I'm wondering how I can export my Microvellum drawing file to an XML file?
Or at the very least how to generate an XML file for Microvellum (instead of exporting an existing project).
My goal is to;
1) Export my .dwg to an XML (or generate an XML)
2) Send the XML to someone
3) They import the XML into Microvellum
4) All the 3D cabinet models and walls are drawn in the same locations that I had in my original dwg.
An article published by Microvellum provides a sample XML file, and this specific XML file imports the cabinet data, wall data, and draws the cabinets and walls in the correct locations (basically as if someone had just sent them the .dwg file instead).
So far, the Microvellum forums and support haven't been able to give me any leads on who I can talk to to learn more, other than saying large manufacturing companies have IT guys that created online shopping carts that generate XML files for product data only.
https://community.microvellum.com/portal/en/kb/articles/xml-import#XML_Import
7/23/25       #2: Microvellum XML Files ...
David Wishengrad
Hi James,
I know the basics of this for import. I have successfully imported projects, with cabinets and parts.
There are several samples on their website that are old which call variable names such as adj_shelf or whatever that don't even apply now.
To use this correctly you are going to have dog down to find the variable names or find them on export.
We can poke at it together sometime if you want of you don't get any further. Message me and we can set a time. It's been a while since I played with it last, but I probably have some notes somewhere from those attempts.
7/29/25       #3: Microvellum XML Files ...
YOgongono Member
Website: https://www.medipakiet.pl/blog/zawal-serca-objawy-...
The most recent reported problem related to Microvellum XML files does not appear to be a widespread specific technical fault uniquely tied to Microvellum itself, but users sometimes inquire about how to export or generate XML files from Microvellum drawings, suggesting usability or procedural challenges rather than system bugs. Official Microvellum support emphasizes keeping software updated to ensure the best performance and functionality, with a help system including remote support and technical assistance for troubleshooting various issues, which would also cover any XML file handling difficulties users might encounter.
7/29/25       #4: Microvellum XML Files ...
David Wishengrad
It appears in AI offered a response that is completely oblivious to the fact that the documentation on their website was outdated the last time I accessed these tools.
The account above should probably be immediately banned.
7/29/25       #5: Microvellum XML Files ...
David Wishengrad
P.S. reason I say that is because it is attempting to mimic the human being and not disclosing that it's not a human being. That should be grounds for removal in my book. Woodweb has always been awesome about removing the spam in the junk so I just thought I'd leave that note.
7/31/25       #6: Microvellum XML Files ...
Gary B.
What specifically are you trying to do? I created a program for us that digs into our other software, generates an XML file that I pull into MV. We do this daily. I place each product in model space, but do not place them on walls, as I have no need for it.
It's very possible but would require some custom coding.
7/31/25       #7: Microvellum XML Files ...
James
Hi Gary,
Thank you for your response, that sounds very intriguing! Can you tell me a little more about what your software does? How did you make it and what information does it use to generate the XML file?
My end goal is to be able to scan shop drawings that are sent to me, create an XML file, and import the product data into Microvellum.
I can't remember if I've mentioned this in my original post, but I have a sample XML file from a Microvellum published article that can import the product data (so I know it works and is possible), but I just can't find anything online about how to generate the file
    • ECabinet Systems
    • The Millwork Studio
    • CabMaster Software
