Computer Aided Design
Molding on KCD
11/21/14
Kevin Member
Does anybody know if I can add multiple types of molding to one cabinet? Specifically, I would like to draw upper cabinets with crown molding as well as light rail. Haven't been able to draw more than just the crown. Thanks
11/24/14       #3: Molding on KCD ...
Chris Hayden
You can use the upper filler on top of your upper cabinet and add molding to that.
11/24/14       #4: Molding on KCD ...
Fred Wholley  Member
Website: kcdsoftware.com
Hi Kevin,
There is a way you can create multiple moldings in KCD, you would use a Filler Top under Top Cabinets, the Top Filler accepts molding. Take the filler and change the height to a 1/16 change the width to whatever you need and the depth can be the depth of the cabinet. After you would click on molding then high lite the molding you want high lite the fillers then Change molding on one or more units, That's it any questions on this please call or email our Tech support, Tech support is Free.
