Computer Aided Design
Snapping Lines in Acad
11/14/17
Paul S
I received a vector drawing made from adobe illustrator and it was converted to a DXF file format. I need to clean it up and connect all the vectors to run a v carve on a CNC. It seems like none of the vectors will snap. I have all the snaps on. Any Ideas how to fix this.
11/14/17       #2: Snapping Lines in Acad ...
Stephen Williams Sponsor - Parts Cutter CNC
Website: http://www.partscuttercnc.com
Its a dxf and you cant snap to a vertex?
Import it into vcarve and go to vertex edit mode and see if it picks up the points.
11/14/17       #3: Snapping Lines in Acad ...
TonyF
Paul:
You mught try running the file through a DXF to DWG converter, either by downloaded or cloud-based software. This should restore the AutoCad proprietary features to the drawing.
Hope this helps. Good luck.
TonyF
11/25/17       #4: Snapping Lines in Acad ...
Dave edgerton
they may not have the z direction as 0. that i what usually happens
