Joints -- 0 --
6/22
Please can someone tell me how can I make 3 joints (marked with red) as in this drawing in cabinet vision? If someone can make a short video it will be very appriciated!
View larger image
6/22 #2: Joints ...
What type of connector are you using. Dowel, Pocket Hole, etc?
6/22 #3: Joints ...
Hi JoeW,
Dowels.
6/22 #4: Joints ...
OK. That is handled in the in your construction method. Look at your construction method under operations and then assembly borin
View higher quality, full size image (1148 X 705)
6/22 #5: Joints ...
Hi again and thanks for your help, but is it possible for you to make a short video from start to finish? It is the first time for me doing these joints.
6/22 #6: Joints ...
EmVella
Do you know how to set up a basic construction method? Have you worked through the solid essential videos?
To set up a dowel joint, you need to know the size of dowel you use and then walk through the construction method.
You will not get it right the first time. So play with a test method (make a copy of an existing method and save it under a different name) and make changes until you get it right.
If you don't make mistakes at first, you will never learn.
I don't now how you build your cabinets. So making a video will not be much help for you. You need to try it on your own first. Just answer each question the best you can and then see what it does. Make changes and keep trying until you get it the way you need it.
Cabinet Vision is a very powerful cabinet program. You can do virtually anything with it. But you have to learn it's basics and have a good knowledge on how to build cabinets.
6/22 #7: Joints ...
Yes I agree with you 100%. As you noticed I am a beginner and I wanted a video just to start with and then I start doing all that you said.
I mean if I see a video of how to do the joints for the picture I posted, than it will be much easier for me to continue playing and testing methods, etc...
6/23 #8: Joints ...
Website: http://www.taghkanicww.com
I can strongly suggest that you get just a couple of hours of online training. You invested in the software that will do it all for you. Invest in the training so you can use it.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
