Computer Aided Design
CADdirect
11/27/19
jonathan mahnken
Anyone have any thoughts and or opinions? price is right and they have permanent licensing
https://backtocad.com/solutions/dwg-cad-system/
11/28/19       #2: CADdirect ...
james e mcgrew  Member
I use the heck outa BTC pdf to dwg
11/29/19       #3: CADdirect ...
jonathan mahnken
Jim is this in order to convert 2d plans that you have received as pdf. do you find the program to be satisfactory for the price?
11/29/19       #4: CADdirect ...
I will blow up say a foot print or cut detail of a desk import the pdf into "Print to cad" and scale then convert to DWG,, from that point i am making accurate parts for Radius desk Etc, I do not use it for its CAD aspect I use Aspire
11/30/19       #5: CADdirect ...
jonathan mahnken
Thanks James
12/1/19       #6: CADdirect ...
David Wishengrad
I use able2extract pro. Cheap enough, does some r2v too, but in all fairness, I do run separate routines of custom code to clean the dxf's up to delete all hatches, points and solids, as well as ones for removing thousands of lines from things like exploded drywall wall hatches, and snapping all lines close to vert or horz perfect and making them all snap to a 1/8" grid, so I don't have any funny number length lines at all unless they are on an angles. I typically load the entire arch set and convert the entire thing, but only further process the pages that I actually need.i seems to work much better than acad's PDFconvert.
Able2extract
