Computer Aided Design
Recessed handles in Cabinet vision
9/15/19
Max Member
I wondering if possibility to create operation that cut material for Recessed handles in Cabinet vision ?
View higher quality, full size image (1900 X 1069)
9/15/19       #2: Recessed handles in Cabinet vision ...
Max Member
Here is dimensions
View higher quality, full size image (843 X 674)
View higher quality, full size image (768 X 702)
9/16/19       #3: Recessed handles in Cabinet vision ...
Tyler Lauzier
Yes, we have done this before in cabinet vision, it worked pretty well.
We drew the handle in google sketchup, then imported it into CV. Then from there went to the 3D Model, and applied routing to the dimension of the pull.
You can skip the sketchup path if you don't need to see or show the actual handle. You can just create a new pull, pick any of the model presets, as it doesnt matter. Choose your location, 3 horizontal 2" vertical etc. Go into the 3D model, delete all of the CV generated processes, and apply your own route to the handle spec.
9/16/19       #4: Recessed handles in Cabinet vision ...
Max Member
I trying but there is no operation generated. I also have UCS for hetich inset pulls but some how no operation . Any idea what to do ?
Inset_Pulls.pdf
2/19/20       #6: Recessed handles in Cabinet vision ...
Bill Buck
do you have the correct material ID in your UCS?
    • The Millwork Studio
    • ECabinet Systems
    • CabMaster Software
