Computer Aided Design
MV dropping dowel machining
2/20/20
Ex-Pat Member
I have a weird one here. On our angled ADA sink cabinet product Microvellum will occasionally not include the dowel hole machining for the sub front in the cabinet sides when it nests the parts. What makes it weird is that it doesn't do it consistently. It is pretty easy to diagnose and repair an error that happens all the time, but this randomness has me confused. Does anyone have an idea of where to look to try figure this out? We are using MV67. Thanks.
2/25/20       #2: MV dropping dowel machining ...
Gary Balcom
Pat,
I'm willing to bet that it has to do with material thickness. The two surfaces must touch, but not intersect. It can't even be 1 thousandth off.
2/26/20       #3: MV dropping dowel machining ...
Ex-Pat Member
Good thought, thanks. I'll look into it.
3/10/20       #4: MV dropping dowel machining ...
Engineer, Jr. Member
One thing that tripped me up was messing with the materials in the Product Prompts then forgetting to uncheck the "Edit Materials" checkbox. For some reason, that did what Gary said and disassociated parts (for lack of better term) and broke the machining as you described. Simply unchecking the box fixed the issue. Hopefully it's that simple.
    • The Millwork Studio
    • ECabinet Systems
    • CabMaster Software
