Computer Aided Design
Mozaik new door style help
4/4/20
Brian Member
I need to make a 1" thick mitred door.
I created the Materials and the Materials Template.
I can't figure out how to make a 1" thick Profile in the Mitre Frame tab of the Door Library. It seems to not allow thicker than 3/4".
Help?
4/6/20       #2: Mozaik new door style help ...
I don't have any experience with mitred doors in Mozaik, but I've screwed up everything else in that program.
I made a material for doors 1" thick. Made a Door Material Template with that material in use for everything. That all shows up correctly, as my doors are sticking out past the frame on inset 1/4" "DoorOutset" parameter set to -.25" should adjust that back in. Also, all my parts are showing up correctly in the parts list.
I didn't see a parameter that would affect anything as far as the door thickness goes, but I didn't expect to see that as with everything else the material template seems to control that stuff.
In Libraries --> Doors --> Mitre Door Tab--> Profile Library. I started monkeying around with one of the profiles that was already on there. I couldn't place a point beyond 3/4", but I could push a shape past that. Which doesn't really help.
With Mozaik, it's almost always something simple and stupid you're over looking. I don't see what the solution is, but I'd just email the help desk or post something to the Mozaik forum. I've had pretty good response from both, though the help desk has been more direct, and posting to the forum can be a iffy whether or not it'll get posted or you'll get a response.
HA! Just figure it out while typing and thought I'd try one more thing. I knew it was something stupid. So go to the profile library. On the left it shows 3/4 in bold. Click on that. Enter your value. Bam, whatever you want.
It's always something stupid.
I should've been cocky and just deleted my thought process like I knew EXACTLY what to do, but screw it.
View higher quality, full size image (1887 X 1074)
4/6/20       #3: Mozaik new door style help ...
Brian Member
That was it. Like you said, often some stupid little thing that isn't obvious.
I appreciate seeing the thought process too.
Thanks.
p.s. I did the Help Desk but I guess there's no one there on the weekend. And they wouldn't put my question on their forum. :-( That's why I posted here.
4/6/20       #4: Mozaik new door style help ...
I don't understand the moderation of the forum. But, it's not my playground, and they can do whatever they want.
    • ECabinet Systems
    • CabMaster Software
    • The Millwork Studio
