Computer Aided Design
Alphacam to Woodwop (Homag machines)
8/4/20
Jeff Atkinson Member
Our company is currently running Woodwop for use with Homag BMG 311 Venture & Homag Optimat BOF 311. Previous machine operator was doing a lot of the programming at the controller (taking the basic geometry created by office - dxf import to woodwop) & adding machining as required.
We do a lot of custom interior / exterior doors, exterior brackets, corbels, rafter tails, and various unique pcs (not panel processing or nesting currently).
Alphacam was purchased but never implemented (before my time) & I was told that it was not used since the machine operator could not manipulate programming when passed from Alphacam to Woodwop? I've recently asked this question to tech & was told that since we have a Woodwop post, we should be able to?
Does anyone have some further insight on this? I'd really like to get this implemented but looking for an overview. In my past, I've used abc/cam, cadcode to process, & was relatively easily controlled through layers (with dxf) & further settings in cam software.
Additional frustration has come from looking into renewing Alphacam service contract & have found that if not kept current, they will increase rate (almost if collecting for yrs not active) for renewal yr.
Jeff
8/5/20       #2: Alphacam to Woodwop (Homag machines ...
Alan F. Member
I don't know about Alphacam but most posts don't use built-in routines or blocks so they can be edited but it isn't the same as editing a Woodwop routine created in the office or on the machine with a stop and end and arc.
A-
8/13/20       #3: Alphacam to Woodwop (Homag machines ...
steve
This CAN be done, but you need a very specific post as the Homag G-Code is as unique as they come.
There is a gentleman named Larry B (I forget exact last name, Burgen, Bergen?) here on the forums that specializes in converting G-Code for different machines.
I run a Homag and can run circles around our SmartCAM programmers with WoodWOP, so perhaps consider training on WoodWOP as well?
8/13/20       #4: Alphacam to Woodwop (Homag machines ...
steve
Wally Bergen
http://www.wbsystech.com/
Sorry Wally, I meant well.
8/16/20       #5: Alphacam to Woodwop (Homag machines ...
Thanks Steve,
We supposedly have a post written for Woodwop specifically, & I'm only in the beginning stages of diving in. From my little experience with Woodwop, there needs to be much further manipulation after a dxf has been read into the program. We only have the basic dxf reader (not pro)...not impressed, but yes additional training on this as well is needed.
8/17/20       #6: Alphacam to Woodwop (Homag machines ...
Marek  Member
Website: http://www.cadcam-softcz.cz
If it is still actual. Let me know.
https://www.youtube.com/watch?v=UczSicQOs-4
    • ECabinet Systems
    • CabMaster Software
    • The Millwork Studio
