Computer Aided Design
WANTED: AutoCAD LT 2008 trial version
10/22/20
BH Davis  Member
Intel tech is working on a video problem in my UHD620 graphics driver. Experimenting shows that manifests itself in AutoCAD LT 2008 but maybe not in later versions.
The Intel tech I've been communicating with needs a copy of that version in order to try and duplicate the problem.
As you probably know getting something from Autodesk is like getting a tooth pulled.......painful. I've suggested the Intel tech contact Autodesk as she might have better luck being from Intel tech support. I'm not optimistic though.
So another option would be to find an old trial version CD to send to her. That should work for a week or two and thus give them enough time to track the problem.
Anyone have one lying around?
Thanks,
11/4/20       #2: WANTED: AutoCAD LT 2008 trial versi ...
Brian
I wouldn't bother with that, put in a real graphics card and move on.
11/5/20       #3: WANTED: AutoCAD LT 2008 trial versi ...
TonyF
Bernie:
Good luck trying to find older ACAD software. Is this a problem that appeared after installing Windows 10? I think that some of the older graphics files don't work or can't be updated on older software running on Windows 10. Also, with some of the older graphics cards, Windows 10 will not update the drivers.
Since all I did was 2D shop drawings, I could still run ACAD R14 (not 2014, R14 from 1997) in Windows 10. Some modifications to the ACAD.CFG file, and it seemed ok, but I could no longer create plot files because the updated drivers either would not run on my software or were unavailable, and so I have an older computer running it on Windows 7, and all is well.
If ACAD 2008 LT worked well in Windows 7 or before, that may be your problem, and you may need to dedicate a computer running that operating system to use the ACAD 2008 LT.
I never bothered with upgrades because it worked for what I needed it for, and its nice to have bought the program and own it, versus paying a yearly subscription.
Hope this helps.
TonyF
11/5/20       #4: WANTED: AutoCAD LT 2008 trial versi ...
BH Davis  Member
Tony,
Thanks. I've put the issue to bed......or that is, Intel tech support has as they can't get anywhere with getting 2008 LT to activate to test. I actually uploaded the complete CD and they downloaded it for a trial.
So I'm going to upgrade to 2014 which I also have. The 08 graphics bug was not a problem on my old Windows 10 laptop so it appears to be an issue with the embedded Intel graphics. Hopefully this will be resolved with the Ver. 2014 upgrade.
I only use this occasionally now that I'm retired so have lived with the 08 problem for the past year or so since getting the current laptop. I just decided to try and do something about it. Since I have a 2014 license on another computer I'm going to transfer it to this laptop and see what happens. If it works better I'll just transfer the 08 license to that old computer.
Thanks again,
    • CabMaster Software
    • Cabinet Pro
    • The Millwork Studio
    • ECabinet Systems
