Computer Aided Design
Oil for CNC router
11/5/20
Ronnie
What type of oil should I use in the CNC oil reservoir?
I hate to sound ignorant, but I'm old school cast iron and was told to get some oil for the CNC. Nobody seems to know what has been used before.
It is a 5' x 10' bed with carousel tool changer.
Do the terms 30c ST -150c ST mean anything?
Thanks,
Ronnie
11/6/20       #2: Oil for CNC router ...
Snaglpuss
Try asking the manufacturer first. We use Spindle oil for our auto lube system that keeps the ways lubed. Mobil Velocite #10 Spindle Oil. We get it from McMaster.
11/6/20       #3: Oil for CNC router ...
Ronnie
Thanks,
I should have thunk of that!
Ronnie
11/6/20       #4: Oil for CNC router ...
Leland Thomasset  Member
McMaster is a great resource for all of these lubricants. I would certainly ask the manufacturer for the spec. also the manuals will have the information if you do not have one just look online you will find it in PDF
11/9/20       #5: Oil for CNC router ...
Word of caution. Mixing lubricants, especially grease can be disastrous. I put some cheaper supposedly "compatible grease in my autolube system years ago. The result was plugged up grease lines running to all the bearings. Had to manually remove all the lines to clean them. A penny saved in supplies sometimes cost a lot of dollars in maintenance.
    • ECabinet Systems
    • The Millwork Studio
    • CabMaster Software
