Computer Aided Design
Cabinet vision and edgebanding
3/16/21
Barry
I’m using melamine doors with edge banding. The cut list is not showing the deduction for edgebanding.
Looked everywhere can’t find the setting.
Regards Barry
3/16/21       #2: Cabinet vision and edgebanding ...
Jared Member
Material manager: does your banding have a thickness value?
Material Schedules: Do you have the banding material applied for the door type you're using? Also look at the left column and make sure Banding shows Yes.
Door Catalog editor: Are you applying banding to the door type you're using? Look at Door catalog editor, Material tab, check all the Apply Edge Banding To boxes.
Preferences: At the splash screen (not when a job is open), go to Preferences, then Geometry. Make sure "Include Banding in Cutlist Part Size" is unchecked.
    • The Millwork Studio
    • ECabinet Systems
    • CabMaster Software
