Computer Aided Design
3D Cabinetry Rendering Website
7/18/21
Eric Member
I made this website for my own use but I thought others might find it helpful.
I wanted something that just did renderings and was simple. It was also an excuse to learn web development.
https://cabinet3js.netlify.app/
View higher quality, full size image (800 X 392)
7/19/21       #2: 3D Cabinetry Rendering Website ...
David Wishengrad
Very nice. This will probably terrify others that you will add cut list and cnc output. As those are child's play if one is driving the 3D graphics parametrically as you already are. You have all the data to do it right there.
About time someone did this.
Thank you. Great work.
7/19/21       #4: 3D Cabinetry Rendering Website ...
Eric Member
Thanks!
I have thought about adding more to it but so far I have fought the urge as I'd like to keep it as simple as possible. One thing I will likely add is a report of all the cabinets and their sizes.
7/22/21       #5: 3D Cabinetry Rendering Website ...
Tim Schramm  Member
Website: http://www.hardlinecorp.com
Great job Eric, very easy to use. Would be nice to have an option to add a filler/scribe to either side of the cabinets.
7/22/21       #6: 3D Cabinetry Rendering Website ...
Eric Member
That's a good idea, Tim.
I'll post here when I have it added.
7/26/21       #7: 3D Cabinetry Rendering Website ...
Eric Member
I've added fillers to all cabinets but the upper corner cabinet. Just use the filler of the cabinet next to it.
Let me know what you think :)
7/28/21       #8: 3D Cabinetry Rendering Website ...
Tim Schramm  Member
Eric, that works great, I did have to replace the cabinets to get the filler option. You may want to add a top & bottom filler to the uppers for a more finished look. Another thought would be a separate item for corner fillers.
7/28/21       #9: 3D Cabinetry Rendering Website ...
Eric Member
About having to replace the cabinets to get the changes; I made it like that so past projects wouldn't get messed up if I changed how an item works. There are pros and cons to that approach.
You're right about adding top and bottom fillers. I'll add those to the uppers.
I think I will also add an upper filler and a base filler under Mill-Work.
The upper filler will have crown attached to it and the base filler will have a countertop and toe-kick attached to it.
7/28/21       #10: 3D Cabinetry Rendering Website ...
Eric Member
I have added those changes.
I'm wondering if it would make more sense to have the upper filler with the upper cabinets and the base filler with the base cabinets.
Right now they are under Mill-Work.
7/29/21       #11: 3D Cabinetry Rendering Website ...
Tim Schramm  Member
That does make more sense, it was the first place I looked for the fillers. Now lets talk about corner fillers, not everyone wants a corner cabinet. I thought about just making a really wide filler at one leg, but the crown would look messed up and the base would leave a hole at the kick. Corner fillers can get tricky a lot of parameters to adjust, piece of cake for web developer pro like yourself :).
7/29/21       #12: 3D Cabinetry Rendering Website ...
Eric Member
I moved the fillers to the uppers and base groups.
Corner fillers... that might be a though nut to crack. I'll have to do some thinking on that one. Good point though.
btw
There are some short cuts that aren't really documented:
F1 to toggle between the floor plan and 3D view.
Edit an item: right click on it OR press "e" when it's selected(red).
Delete an item: select it then press the delete key.
Move an item: press "m" when it's selected.
Move an item UP: press the up key when it's selected.
Move an item Down: press the down key when it's selected.
Move an item Right: press the right key when it's selected.
Move an item Left: press the left key when it's selected.
Also; all inputs should handle fractions.
8/6/21       #13: 3D Cabinetry Rendering Website ...
Eric Member
I've added item reports. It builds a .csv file to be opened in a spreed sheet program.
It only lists some of the more important properties like dimensions.
Still thinking about corner fillers. One idea is to have a property in the corner cabinets that would say something like "Act as a filler" or "Filler Box".
View higher quality, full size image (617 X 284)
8/12/21       #14: 3D Cabinetry Rendering Website ...
Eric Member
David, I started to add cutlists like you had mentioned.
Right now it's just an experimental feature. And only works with newly added standard uppers. At the moment the only option for the user to adjust is the cabinet material thickness. I think I might add a few more options like a back inset etc. But still trying to keeping it as simple a possible.
View higher quality, full size image (685 X 120)
9/30/21       #15: 3D Cabinetry Rendering Website ...
Eric Member
I got a real domain name for the site now.
www.cabinetfree.com Get it? It sounds like cabinetry lol
I've almost finished the cutlists for all cabinets.
The cabinet numbers show in the floor plan view.
You can save an image of the floor plan.
Added optional end panels to most cabinet.
And have started a blog about any new features.
https://www.cabinetfree.com
10/18/21       #16: 3D Cabinetry Rendering Website ...
Robert Williams
Eric,
Nice job on the website. Is it built with three.js?
10/18/21       #17: 3D Cabinetry Rendering Website ...
Eric Member
Thanks Robert!
Yes it is. Do you program as well?
1/28/22       #18: 3D Cabinetry Rendering Website ...
Chuck Fox Member
Nicely done! Added this tool to my browser bookmarks
1/29/22       #19: 3D Cabinetry Rendering Website ...
Eric Member
Thanks Chuck!
Let me know if you have any problems or suggestions.
I don't have a lot of time these days but I'll do my best to make it better.
https://www.cabinetfree.com/
    • The Millwork Studio
    • ECabinet Systems
    • CabMaster Software
