Computer Aided Design
Cabinet Vision Nesting
8/11/22
Glenn Nellis Member
We use CV 11 and 12 anyone have a solution to make the part number on the nest match the cabinet #? Sometimes when it nest the part #'s are all over the place causing the operator to label parts wrong. If the part # matched the cabinet # I think that would help eliminate confusion.
8/12/22       #2: Cabinet Vision Nesting ...
Colby Ellis
This is not possible. You can edit the PDF nest report manually but that would be such a pain in the ass.
8/12/22       #3: Cabinet Vision Nesting ...
Glenn Nellis Member
Thank you for the response.
8/12/22       #4: Cabinet Vision Nesting ...
Colby Ellis
If your CNC has the ability to label parts you could look into that. I've heard that a lot of shops that started using labels would never be able to go back because its just so much easier to keep track of things.
8/13/22       #5: Cabinet Vision Nesting ...
David Wishengrad
This could probably be easily done in a day with c# and netdxf, and using those to correlate the correct info, then identifying the places in the output and modifing those as needed. It doesn't sound too hard at all. I am not sure, but it almost definitely not a not a problem. You can contact any cad coding company and talk it over with them.
8/14/22       #6: Cabinet Vision Nesting ...
Derrek
Website: http://www.closetdr.com
We use label it with cv. Part numbers match and you can select what info we want on the label including edgebanding.
Closet Doctor label set up
    • ECabinet Systems
    • INNERGY
    • Cabinet Pro
