Computer Aided Design
5 axis stl matching program prep
11/4/22
Ian
Hello, I use Alphacam 5 axis ultimate regularly in a 2d and also solid model type machining theme but am looking to use some STL files I've had for awhile of some higher end architectural. It would be mostly corbels- 3 sided with unmachined flat top & back. Is there an easy way to break this type of model down into work plane machining one side at a time? I like to overthink stuff sometimes....
11/7/22       #2: 5 axis stl matching program prep ...
Jared
I'm sure there are plenty of alternatives, but Vectric Vcarve can digest STL models and it's not expensive. It's useful for dealing with things my normal cabinet software chokes on: splines, lettering, sculpting, etc.
11/7/22       #3: 5 axis stl matching program prep ...
Ian
Yes, I have vcarve pro also, but looking to do multi- sided machining simultaneously
    • ECabinet Systems
    • Cabinet Pro
    • The Millwork Studio
    • CabMaster Software
