Computer Aided Design
Help needed with CAD
8/21/23
Prim
Hi, does anyone have experience with CAD as far as using it with a 3D printer? What program or software can you use to transfer the design to the printer, preferably one that's open source?
8/22/23       #2: Help needed with CAD ...
David Wishengrad
Hi Prim,
This is not an area of expertise that I have, but with that said, I know some.
First of all, depending on what you are attempting to accomplish, you will need a list of machines that could be used and the formatting of the requirements to run them.
From there you can better look for the open source code. There are a lot of options and different techniques.
Depending on what you are doing, it may work out better for you to buy something already canned and contend with whatever it may present with difficulties.
Printing something may be based on some standard formatting or not.
For instance, many people do not know that most of chips that run standard 2d printers understand HPGL, and so that one can send a text file to a printer at a command prompt with no driver to format the file, if that file is already formatted in HPGL or HPGL/2. I have a piece of free software called Plot .PLT files that was nothing more than a window that ran a .bat file at a prompt which did just that. This was before people finally figured using CAD for many things and many drawings were not digital in the first place.
So, knowing more helps direct a better answer. There are a lot of different things that people can recommend.
Hobby? "Professional" (that's a dirty word, lol) level?
8/22/23       #3: Help needed with CAD ...
james e mcgrew  Member
What are you trying yo do, Files are vreated as .stl , .obj , (2.5d files created on related software) then exported and inported into software which processes this for a 3d printer. some simple ones are generally available when a 3d printer is purchased, I have 5 large printers but your question is to vauge to answer much further. what is the situation ?
8/23/23       #4: Help needed with CAD ...
Justin Morris  Member
Website: https://www.centexautomation.net/
A lot depends on the brand and model of the 3D printer you are using. Without that info, hard to help you out
8/29/23       #5: Help needed with CAD ...
Aaron Newswanger  Member
Website: http://www.blueballmachine.com/
Creality makes a easy software to use, but again it depends a little on the printer you have
8/30/23       #6: Help needed with CAD ...
User 3-D Member
You're looking for a slicer program. I use UltiMaker Cura and have been happy with it. You can save presets for different filaments or qualities of the prints and I haven't had any issues importing from 3D models generated from AutoCAD.
My workflow typically goes like this: Idea --> sketch --> 2D drawing --> 3D model --> Fast print for dimension checks --> --> Revise model --> high-quality print (if desired).
    • ECabinet Systems
    • CabMaster Software
    • The Millwork Studio
