Computer Aided Design
Autocad scripts trouble
9/29/23
Billy Ray Lobb
Trying to write a Autocad script , The first commands work ok but it wont read the second command it just goes back to first command . Any ideal Thank
Here is the scripts
RECTANG
Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]: 0,0
Specify other corner point or [Area/Dimensions/Rotation]: 16,14
_OFFSET
Current settings: Erase source=No Layer=Source OFFSETGAPTYPE=0
Specify offset distance or [Through/Erase/Layer] :
Select object to offset or [Exit/Undo] :
10/8/23       #2: Autocad scripts trouble ...
David Wishengrad
Quick guesses
you are not using _non, and if your osnap is on your results will snap to the the wrong coordinates.
(you properly should have posted the script)
you are missing or adding 1 or more returns that should not be there.
I have c# code that automatically writes dynamic scripts on the fly. It even types into acad to tell acad to run them after it is done making them. It work very well. The implications.... ???? :)
make sure you use ._ and - and _non before any set of coordinates.
It most certainly is worth learning what is possible with scripts. I have found that they do things much,.much,.much faster than people realize, even people who write code for acad. Dynamicly creating them on the fly from code opens a lot of possibilities.
If you don't figure it out then email me and I will take a deeper look.
Good luck...
10/9/23       #4: Autocad scripts trouble ...
Billy Ray Lobb
    • The Millwork Studio
    • Cabinet Pro
    • ECabinet Systems
