Computer Aided Design
Cabinet vision
7/24/19
Joseph Eultgen
Website: http://eultgenwoodworking.com
Patience with this question please. I'm a bench hand. Not a program guru.
Our firm uses caninet vision 11.
We produce a wide variety of products. When we cut architectural panels. Can you program them to run face down and identify on the program ...room numbers, seam joints, edge banding edges?
Thank you for your time.
Joseph
7/25/19       #2: Cabinet vision ...
Scott Gibson Member
Website: http://momentumwoodworks.com
Panels that have operations (hinge cup holes being cut) will automatically run face down. If you call out the material as being good one face then it will be run face down as well. If you use CV-Label-It then you can apply your room specs, etc. on the labels for each part.
7/25/19       #3: Cabinet vision ...
Tyler
The simple answer is yes to everything. Lable it will map out all of your rooms, cab number, and where to EB. Generally it's safe to trust CV panel appropriation. It's as simple as CV figuring which side needs face machining, (shelf pins hinges mounting holes etc) and having that face go up. Anything that needs machining on both faces will get a backside op
7/26/19       #4: Cabinet vision ...
Leland Thomasset  Member
Yes you can totally control face up and down by selecting as said above a good face in the cabinet construction method set up.
2/7/20       #5: Cabinet vision ...
eric Member
Sup guys!
i'm looking for an easy way to change the grain direction in cabinet vision. Do you have an idea ?
2/19/20       #6: Cabinet vision ...
Bill Buck
Eric- Grain direction for doors or cases?
2/20/20       #7: Cabinet vision ...
eric Member
HI Bill
The thing is i already have all my cabinets done but the client decided to change the grain direction. So i have to change the grain direction of the cabinet and the doors. i know i can build another one from scratch if i change the settings in my cabinet assembly method but since they are already done i would like to know if there is an easier way to change the grain direction. Thanx for your help !
12/12/23       #8: Cabinet vision ...
Dustin Long
Well, it's a "Zombie thread" but I found the messages in a web search, and then I found an answer. Posting it here in the hopes it helps someone else.
I was able to change grain direction on finished ends in CV11 by going to "Room Properties" -> Cabinet -> Construction Methods -> External Case -> Finshed Ends. There is a "checkbox" in the interview dialog 2 screens in that allows finished ends to flip grain. Check this box, click Next and Save/Exit to allow the room to be updated with changes.
View higher quality, full size image (903 X 757)
View higher quality, full size image (970 X 757)
    • ECabinet Systems
    • CabMaster Software
    • The Millwork Studio
