Computer Aided Design
Cabnetware along with Cabinetvision
5/2/24
Jonathan Canatella Member
We've been using Cabnetware for 25 years but bought in to Cabinetvision when Ware was discontinued. We also use Alphacam. Did Cabinetvision change its Microsoft Data Base Files recently? Our Cabnetware and Alphacam no longer recognizes the MDB files.
5/7/24       #2: Cabnetware along with Cabinetvision ...
Cliffman Member
Reinstall CW-14 over Vision. Should work.
5/9/24       #3: Cabnetware along with Cabinetvision ...
Jim Diebolt
Website: https://forum.designsbydiebolt.com/viewforum.php?f...
Cabnetware Full Tech Support Available Now
I have a Cabnetware Full Tech Support and User Forum for cabinet makers that are staying with Cabnetware. It is full-service tech support with all updates on past versions and builds of the software plus many documents about the software along with tips and tricks plus more. You can find all the information about the forum at this link: Cabnetware Tech Forum. I also have access to two of the best (former) Planit Technicians that are retired and are members of the forum.
I also have an option to make a free backup copy of your security in case something happens to the one you are using now.
If you have any questions, please call, or email me.
909-851-7972
7/4/24       #4: Cabnetware along with Cabinetvision ...
Gogo Member
Website: https://wattsan.com/
It sounds like you've been through quite a journey with Cabnetware and Cabinet Vision. From the information available, Cabinet Vision recently updated their software architecture and data management, which may be causing compatibility issues with older Microsoft Database (MDB) files. This could explain why your Cabnetware and Alphacam systems are no longer recognizing these files​ (Hexagon Nexus)​​ (Furniture Production)​. You might want to reach out directly to Hexagon's support for a definitive solution or look into possible software updates or patches that address this compatibility problem.
2/17/25       #5: Cabnetware along with Cabinetvision ...
Xavier Atkins Member
Hi,
It sounds like you're dealing with a compatibility issue between CabinetVision, Cabnetware, and Alphacam. CabinetVision has indeed made updates over the years, and it's possible that changes in the software's database handling could be affecting how the MDB files are recognized. CabinetVision transitioned from using Microsoft Access databases (MDB) to a newer format for data storage in recent updates, which may be causing the issue you're seeing.
I’d recommend checking the release notes or reaching out to CabinetVision support to verify whether there have been any changes in the database file format. In the meantime, you might want to look into any available import/export tools or scripts that could convert or sync the older MDB files with the new format.
If you have a version backup from when everything was working fine, you could also try reinstalling or restoring from that point. If nothing works, you might want to consult with Alphacam support to see if there's a workaround for recognizing the newer file formats.
Good luck, and hope this helps!
Best,
    • Cabnetware Support
    • The Millwork Studio
    • CabinetCRUNCHER
    • MaxCut Software
