Computer Aided Design
polyboard
2/15/24
Luke Maendel  Member
Hi all, has anyone used ployboard from Wood designer in Canada or the USA? Just wondering how is the learning curve to use ployboard. I have a SCM Pratix cnc that i am using.
2/18/24       #2: polyboard ...
Michael Member
Website: http://lazaroujoinery.com.au
Polyboard is wonderful.
You'll be up and running with single-part code to your SCM, probably out-of-the-box.
I don't know your toolchain from DXF -> XXL, as I use Polyboard+TopSolid`Wood -> Optinest (also excellent) -> CADCode (applies the toolpathing).
Others use Polyboard -> EnRoute, Polyboard -> AlphaCAM.
It's possible your SCM has Maestro, and Maestro will do that CAM for you
(Polyboard -> Maestro) but you'll likely not have part labels that way...
With Polyboard, you'll be making cabinets same day, and libraries the next day, it's dead simple, and a great choice. The only little bit of learning/fiddling comes, if you have 3D models attached to your 'fittings'. Ie. robe rail ends, drw sides/slides, etc. That bit is finicky.
2/20/24       #3: polyboard ...
Luke Maendel  Member
Thank for the info Michael. I will be using Maestro, thanks for all the other options.
7/12/24       #4: polyboard ...
DanielHarlow Member
I completely agree, Polyboard is a great piece of software. The ability to simplify the process from single-part code to your SCM is impressive. It's nice to be able to run it right away, without too much installation.
    • ECabinet Systems
    • CabMaster Software
    • The Millwork Studio
