Computer Aided Design
Door & Window Screen to Machine Design Software Recommendations
7/18/24
Jeff Arwine Member
Hello all,
I would love to hear from anyone that manufactures custom wood doors and wood windows and learn what your company uses for parametric design software that has screen to machine and cutlisting capabilities.
We have been using 2D CAD forever and would like to take it to the next level.
We are a custom door, window, shutter and column manufacturer in Charleston, SC. I appreciate your input and real-world experience and suggestions.
Thank you,
Jeff Arwine
Lead Impact Design Specialist
7/23/24       #3: Door & Window Screen to Machine ...
Dan Jensen
Jeff,
For window and door manufacturing, products like SolidWorks or Autodesk Inventor are highly suitable. These products offer strong parametric capabilities.
If you need more information about Inventor products, I recommend reaching out to Steve Widom at Widom Associates. Steve is very knowledgeable about using Inventor in the wood industry.
Widom Associates
8/2/24       #4: Door & Window Screen to Machine ...
Jonah Coleman
Website: http://www.innergy.com
The Eurosoft guys have something that looks interesting: http://www.eurosoftinc.com/products/doors.aspx
10/9/24       #5: Door & Window Screen to Machine ...
kingbreasts Member
As far as I know, you can try AutoCAD Rhino3D Cabinet Vision& Mastercam
2/17/25       #6: Door & Window Screen to Machine ...
Edwin Dillon Member
Hi Jeff,
It's great to hear that you're looking to upgrade your design process. For parametric design software with screen-to-machine and cut-listing capabilities, there are several great options to consider. Many custom manufacturers in the wood industry use software like SketchUp with plugins like SketchUp CAM or Rhino with RhinoCAM. These programs are known for their flexibility, and Rhino, in particular, offers advanced parametric design features and compatibility with various CNC machines.
Another option is Cabinet Vision, which is tailored to cabinet and custom woodwork manufacturing, with full integration for CNC machining and detailed cut-lists. Fusion 360 is another solid choice if you’re looking for something more comprehensive, as it combines parametric design with CAM functionality and could work well with your needs.
It would be beneficial to also look at software specifically designed for woodworking, like Mozaik Software, which focuses on streamlining custom woodworking and integrates directly with CNC machines.
Each of these has its strengths depending on your workflow, but they all provide the ability to create parametric designs, generate cutlists, and interface with machines effectively. I hope this gives you some good direction as you look to take your processes to the next level.
Best,
    • Cabnetware Support
    • Panel Genie
      Software to optimize Cutting of sheet goods
    • The Millwork Studio
    • CabinetCRUNCHER
    • MaxCut Software
