Computer Aided Design
BricsCAD
7/19/25
I am hearing a bit of noise out there about BricsCAD. I am an AutoCAD user, been using it for 25 years. Anyone here using it? Can you describe the learning curve coming from an AutoCAD world? Functionality? We also use Microvellum for cabinet output, but not desks or diewalls. Desks and Diewalls are drawin manually in AutoCAD and 3d solids if complex. Sometimes shop drawings are better understood with 3 dimensional drawings.
7/19/25       #2: BricsCAD ...
Thomas M Diel  Member
Website: http://thomasdiel.com
Your timing is uncanny!
I am in my first couple days of use on the free download I am liking it quite a bit! Cost, perpetual license and David Wishengrad's Woodwed recommendations from previous posts and coming up on 60 w/ retirement in the future have all guided my decision (not to mention blown drive forcing an upgrade). I am an Autocad 2003 to V2011 user, so no knowledge of updated Autocad from V2011 up current. I am a solo designer / fabricator that drafts in 3D as well as 2D and have to say so far the switch is pretty seamless. I like the BricsC USC better, but rightclick (known issue) and Osnap R-shift grabs seams a bit glitchy in Brics. My workflow is generally 2D into 3D and when I edit 3D I go back to 2D and work back up verses editing 3D models. I guess I feel this method is more accurate but I am old school so I keep the more complex 2d constructs next to 3D models for editing ease. I don't use CAD fulltime as I did in the past, an the last couple days have taught me I don't want to be a full time desk jockey so no steep leaning curve appeals to me. Haven't done any rendering yet but which looks a bit different and need to work w/ it... Command prompts seam the same but w few changes and wont miss Pedit into solid polyL command sequence vs Brics Join. When all else has failed I go back to Brics drafting classic workspace and there at the top are most of the drag down options. Utube U has been helpful as well as their hint prompts. I think based on this first very brief intro I will purchase Brics Pro perpetual, very impressed?
I think I will still investigate Fusion 360 for its native CAM aspect but don't have a CNC thus far and haven't programmed in last 14yrs w/ experience via Komo's RouterCIM CAM 2006 that was native in Autocad, but still hoping for a magical CNC w CAM to fall from the sky.
Weyco_full_model.pdf
7/19/25       #3: BricsCAD ...
Thank you for the reply. Fusion 360? I did look into that. No 4th axis abilities. I was talking to their development people and showed them my YouTube channel. They said no to helping me at this point. Maybe in the future.Again, thanks for the input. I value that.
    • The Millwork Studio
    • ECabinet Systems
    • CabMaster Software
