Computer Aided Design
The 'One' Program
4/20/25
harryperry Member
I'd love to hear what approach people are taking with CAD to CAM, mostly because we're currently scratching our heads on the software end of the streamlining process.
We currently use up to five separate programs (depending on what we're doing) to get from drawings to machine.
Archicad: 2800/year
To import drawings to scale and to design our solid surface fabrications. Also for fancy renderings, presentation drawings, submittals, and DXF export. An amazing CAD/drawing program, but no CAM.
Campus: About $5k per seat.(Campus is the software sent with the machine, basically a suite of tools for design-to-machine including aCADemy and HOPs)
aCADemy to import DXFs and add Tool Paths for export to gcode. aCADemy is great for adding tool paths, but is TERRIBLE for drawing, even though that's one of its main purposes. AND, it doesn't like imperial so I spend a lot of time converting and using a calculator. No, really. Every morning one of the first things I do is open a tiny browser window with an inches to mm conversion.
HOPs for basic design, machine macros, & to send gcode to the machine. Basically, everything ends up in HOPS as the last step before machining.
Adobe Illustrator Probably $1k-ish per year? (Part of a yearly subscription to Creative Cloud)
Basically we use this to create text for export as DXF when we need to add lettering to solid surface. Every other program seems to be really lacking in flexibility when creating text for machining. We also use this program to create "Traces" of image files for export as DXF. (Think, grabbing an outline of your state or some other design, as a jpeg or png, tracing the outline and exporting it as a dxf)
Mozaik Software: 2k-ish/yr
For all of our basic millwork/cabinet nesting. Exports directly to gcode with the machine Post. Mozaik is fantastic at cabinetry. Really. Simple yet powerful.
So, is there "One Program to Rule Them All?"
A unicorn of a program that allows for easy 2d drawing and creation/manipulation of 3d objects, handles shapes and text well, easily imports and exports DXF files, creates professional layouts for bid submittals, easily creates nested cabinetry, AND creates tool paths?
4/20/25       #2: The 'One' Program ...
I don't have it because it does not support rotary axis programming, but you might look into Autodesk's Fusion 360. If they make a post for your Holtzher, that may be the one that does it all. Lettering, 3d, submittal quality drawings, etc.
4/23/25       #3: The 'One' Program ...
Matthew  Member
Website: westworldco.com
I don't think it exists or ever will. There just isn't the market for it. My system is Sketchup + CabinetSense plugin for boxes, AutoCAD and MasterCAM. I think for most people, any CAM program would work.
I got lucky in that AutoCAD and MasterCAM are fully paid for (not subscription), so I think I spend maybe $2k/year on Sketchup and CabinetSense. I spent years searching for something more streamlined, but then just accepted that it doesn't exist and just optimize what I have as best I can.
5/4/25       #6: The 'One' Program ...
yaakov Member
Yes ,our software,it's new,it's full parametric ,and because it's solid object base ,we can do all types of cabinet ,round,slopes,also MDF engraving you can see on project as really
We can support all kinds of CNC ,4,5 axis
Auto label,dril head ,second CNC
5/28/25       #7: The 'One' Program ...
Dave Hoder  Member
Website: http://www.triageinfoservices.com
You didn't mention what kind of work you do but Microvellum (AutoCAD based) or Swood (Solidworks based) are both all in one programs. Where I work we use Solidworks with Pathfinder 3D and Enroute.
9/7/25       #9: The 'One' Program ...
Sasha Member
Hello from Russia. In our country, we use the program bazic
    • ECabinet Systems
    • The Millwork Studio
    • CabMaster Software
