Computer Aided Design
Cabinet vision 11
8/21/26
Lee Member
Issues with cabinet vision 11: While doing editing to boring changed part material on its own. Placing in drawer boxes automatically added very small piece of uv material, when select 5/4 face frame change depth of box the face frame separates from cabinet and does not change box depth. Fillers with build ups enter required sizes but when open part size in material list did not change and have change manually. When done save job but when get back in seems like some things did not save ie: light rout Ran all matching but when open job back up not all machining settings did not stay. Corner cabinets change height just separates / blows apart all the cabinet components. It’s to the point where I have to manually check all parts in cabinet vision make sure they are correct including materials are correct also. Really cannot trust what CV is producing is correct. There has been several users before me so not quite sure how they have CV set up or have changed.
8/22/26       #2: Cabinet vision 11 ...
David Wishengrad
You might want to try screen recording with OSB what it is that you are doing and the problems that you are having in a video and then uploading the video to Google's AI and see what it says. It could help identify a host of bugs and or solutions that you can easily then pass on to their development team and managers.
And if you are feeling really daring try to get Grok to patch the actual software in memory in real time. If that works... please let us know. :)
8/22/26       #3: Cabinet vision 11 ...
David Wishengrad
P.S. find all the documentation you can, instructions, help files, developer documentation, even forum posts as pdf's. Explain in a few words that you are having many issues and tell it that you will be uploading the info, then do that, then send the Google AI your video of problems. Put all of it, including a transcript of your entire conversation with the Google AI in a folder on your drive too, so that you can use an agent like Composer/Grok/ Codex, etc. to guide and teach you on your mistakes and or give you work-arounds for the ones in the software that you can't change or possibilities to get it changed. Maybe you spend 20 on 2 plans for 3 months. Well worth it and you will be up to speed and intelligently moving on to better. Good luck
    • The Millwork Studio
    • MaxCut Software
    • Cabnetware Support
    • CabinetCRUNCHER
