Hi everyone, I’m Yazan, the developer of **Kerf360**, a cabinet-making add-in available on the Autodesk App Store.
I built it to automate the repetitive work between drawing a cabinet layout and preparing it for manufacture—all inside Fusion.
You start by drawing one rectangle per cabinet on a floor-plan sketch. Kerf360 turns those rectangles into parametric cabinets. Sketch text controls individual cabinet options, construction lines divide compartments, and L-shaped profiles create corner units.
From that model, you can generate:
- Cut lists in millimetres or fractional inches
- CNC nesting layouts or table-saw breakdowns
- Hardware drilling, including Blum / System 32
- QR part labels and assembly sheets
- Costing CSVs and quote PDFs
- Fusion Manufacture setups and G-code, or layered DXF files for other CAM software
**Watch the demonstration:**
https://youtu.be/8lHYj3gTz0o
**Product details:**
https://kerf360.com
For those designing or building cabinets: **what part of your current design-to-production workflow takes the most repetitive work?** I’d be interested to hear which construction methods or shop requirements Kerf360 would need to support for you.
