Subject: Re: WoodWop - DXF import
8/23/14
Casey Member
This is the first time I am trying to use WoodWop 5.0. I usually either use cabinet vision or just design in autocad. I'm trying to import a dxf file from autocad (which is attached) but I'm getting an error "polyline curve is not initiated." There are only 2 layers; 1 for a 1.5mm deep groove using a .25 router and 1 for a .5 router to cut the piece out.
I already scaled the attached to 25.4 (so hopefully it imports in the correct size). The board used should be ~1/2"x4'x8'.
Please help me..........
View higher quality, full size image (1919 X 1079)
woodwop_example_8_23_14.dxf
8/24/14       #3: WoodWop - DXF import ...
Johann Huck  Member
Website: http://www.themachinewarehouse.com
Casey,
You have not specified the correct layer names in your DXF file. WoodWop does not know the size of the material as per the layer name. Take a look at the link below on how to correctly name your layers.
Johann Huck
The Machine Warehouse, LLC.
704-839-6615
johann@themachinewarehouse.com
WoodWop Layer Names
