Subject: Re: CNC Schematics
CNC Schematics
9/30/14
Ariel Member
Website: http://murphybedsales.com
Does Anyone Have the Schematics for a Laguna CNC Smartshop 2 router? Im willing to purchase it for a fair price..
View larger image
10/1/14       #3: CNC Schematics ...
james mcgrew Member
Not to state the Obvious but wouldn't Laguna have this, these are common Foreign mass produced machines ? Other than the control hardware the wiring should be pretty straight forward ?
10/1/14       #4: CNC Schematics ...
Ariel Member
weve had so much problems with laguna that were deciding to look elsewhere for the schematics...
10/1/14       #5: CNC Schematics ...
Frank D. Jimenez  Member
Website: http://www.cabinetpro.com
Hi Ariel,
Remember: Laguna does not make their CNC routers. They are imported from China with Laguna's name put on them. So if you Google for your schematics, Google the NAME of the controller being used, assuming you are looking for the controller's schematics. And make sure it is the SPECIFIC controller that you are using. (a Mach 3 controller, for example, that was made in 2005 may or may not be the same Mach 3 controller that is made today - OR altered for a specific machine.)
We have a customer with a Chinese router equipped with two spindles. When trying to get tech support on how to use the two spindles INDEPENDENTLY from each other, he hit a major brick wall. So we had to make a change in our software to operate his two spindles independently because no one knew of any command that could be used to accomplish that for his controller. So I wouldn't put too much effort in obtaining your schematics directly from the Chinese company that made your router. I think searching via Google is your best avenue. Good luck Ariel.
10/1/14       #6: CNC Schematics ...
ken
If you want a trouble free system that works, retro fit the controller to wincnc. Kelly and Mike over there are great and talking with the folks that make the controller, makes all the difference when you have a question.
10/1/14       #7: CNC Schematics ...
james mcgrew Member
I too am A Giant fan of Wincnc !!
10/1/14       #8: CNC Schematics ...
Ariel Member
I Appreciate the advice given here on this thread thank you so much... I will refine my search for a controller instead of Schematics... if you think of anything I might have missed any suggestions would be great! once again Ty!
10/2/14       #9: CNC Schematics ...
cabinetmaker
What's the problem ?
10/2/14       #10: CNC Schematics ...
Ariel Member
Well, Thank god that atm our CNC Machine is working fine. Though if it does break down we don't have a way to fix it. We've been talking to some CNC repair techs, and they all say that in order to fix our machine, they would need the schematics. Our Controller is a B&R Model "PP65"
10/2/14       #11: CNC Schematics ...
Ralph Schnader
Does Laguna have a service contract you can buy for used machines? Most companies are willing to sell this and even an extended warranty. Worth a call at least.
