Subject: Re: import .tpa into genesis question
10/17/14
Matthew Durand Member
Hi
Looking at using a third part software for creating engraving, this software outputs .tpa files which is for my machine at work but i cant see how to import these .tpa files into genesis.
Dont know if the .tpa needs to be ran through some sort of converting program
Any ideas how this is done please.
Many thanks in advance
10/21/14       #2: import .tpa into genesis question ...
yaakov
genesis is Albatros just onther name
so generaly shuld be no problem ,maybi need some fix
or because the year diferents
if you want send me sample of Tpa(tcn or cnc files)
and the genesis file try to help
10/31/14       #3: import .tpa into genesis question ...
Bill Blackmon  Member
Website: http://www.casadei-busellato.com
Matthew,
Not sure if you are still looking for an answer or not. The file type .tpa is not associated with Genesis or Genesis Evolution. It appears to be a graphics file associated with Corel Draw. You would definitely need a post of some sort to convert to CNC code.
