Subject: Re: Rover A3 Horizontal Boring
1/30/15
Brian
Horizontal boring works fine on the left side of the machine. When I move to the right side and "mirror" the boring units come down on top of the panel, not good.
Has to be something simple, Right?
Thanks, Brian
1/31/15       #2: Rover A3 Horizontal Boring ...
cabinetmaker
Yes- is the panel length correct ? The tool table will compensate for the tool length plus clearance, so most likely it is panel length.
1/31/15       #3: Rover A3 Horizontal Boring ...
dylan
it looks like your drills are not set up for symmetrical drilling..the ones one the left should in the drill setup have a mate that is symetrical to it..Ie 1 to 10 if in vertical drilling. I attached the pages from the manual..you need to look at machine configuration ck the symmetry for the horz.
good luck..as always..service@biesseamerica.com is also avail.
Dylan Bayliss
View higher quality, full size image (1600 X 900)
