Subject: Re: Dust Hood
Dust Hood
3/26/15
John McFarlane
our Heian CNC router dust hood has 3 settings; M75 for up, M522 for middle & M76 for down. Seems it can't recognize the M522 and goes straight down even when M522 is programmed. dust hood brushes gets bent out of shape when shorter tools are used.
Any solutions?
3/30/15       #2: Dust Hood ...
Mike McClaran
Website: http://www.greenbvc.com
On a Biesse there is an aluminum puck that pushes pneumatically on the down piston. This acts like a brake against the piston shaft. This aluminum puck is a wear item. Sounds like a mechanical issue. Or there might be a sensor issue. On a Biesse there is a metal bar passing the sensor for each position. Hope this helps.
3/30/15       #3: Dust Hood ...
John McFarlane
Thanks Mike. We thought it was just a mechanical problem but the sensor seems unable to recognize the programmed M codes. Had to call a tech to sort it out. Was hoping someone else had similar problem and an easy fix.
