Subject: Re: Weeke Drill Block bit sticking
4/5/15
Dean M Member
I was wondering if anyone else has had this happen? We purchased a used Weeke BHC 280 4/9 Flat Table router a couple years ago and had a couple of drill bits in the drill block stick in the down position while drilling adjustable holes and then bend when moving to the next position. We thought this was a one time thing and changed the bit, but to only have it happen again. We decommissioned the bit because we could not figure out why this was happening. Recently we had a technician come in and look at it and said to use some 1200 grit emery paper and polish the shaft and use the lubricant the machine uses on the drill shaft.
Before I do this, I was wondering if anyone else has had this happen and how they repaired it. Are the individual drill shaft able to be changed in case it has a slight bend in it? We can get it to move up by pushing up on it when it is stuck in the down position. It seems to be tight at the very bottom, but moves smooth as soon as you give it a slight push up and it pops right up again.
Any help will be greatly appreciated as I am out of ideas.
4/5/15       #2: Weeke Drill Block bit sticking ...
Gary B.
Dean,
I think I'd listen to the tech; seems like the easiest solution. Other than that, you're probably looking at having the drill block rebuilt. That won't be fun (block will be down for a while), or cheap.
4/6/15       #3: Weeke Drill Block bit sticking ...
Dean M Member
That is what I am thinking, But I still don't know if they can change single drill shafts.
4/6/15       #4: Weeke Drill Block bit sticking ...
yaakov
i can tell you how its in biesse(HSD)maybi
weke is the same
you have spring in the cilynder that push up the drill bit
and its quit easy to reaplace only one spring
also you can reaplace only one shaft without take off the drill block its not so complicate work
when you take out the specfic bit ,must order the corect bit(R or L) and also the all kit for this cilynder
some type also importent the specfifc position because not all are the same
4/6/15       #5: Weeke Drill Block bit sticking ...
Dean M Member
Thanks Yaakov, I will check into that.
4/7/15       #6: Weeke Drill Block bit sticking ...
What our drill spindles look like apart. Had to replace some parts because previous owner didn't lube. Pretty easy to take apart. There are holes in the plates that allow push bolts to be used for dis-assembly. The photo is of a horizontal drilling unit.
4/7/15       #7: Weeke Drill Block bit sticking ...
Dean M Member
Great picture Larry. Is that a Weeke? I spoke to Homag and they said that mine can come apart and replace the parts if I want. I think I will take a shot at it. But they said there were no springs, everything runs on air for push and pull on the vertical drills. So it would be likely
that the same thing happened with the last owner, no lubrication checked. Thanks
4/7/15       #8: Weeke Drill Block bit sticking ...
Drill box wasn't made by Komo but installed on it. If you take yours apart, carefully lay out the parts in order & photo. Seems like it would be easy for a shaft to get bent just enough to stick. As long as we had ours apart, we replaced all the bearings.
4/9/15       #9: Weeke Drill Block bit sticking ...
cabinetmaker
Buy some Lusin from BVC or CNBC-tool.com. Drop the spindles from the controller and clean and sand - then lube. You would be shocked as to how many owners do not demand regular maint and then bitch when the machine won't make a tool change or operate properly. Good advice from the tech
