Subject: Re: cnc accurecy
cnc accurecy
4/20/15
Gilad
HI I could use some advice with my new cnc machine.
I mainly use the machine for cutting laminated MDF meant for cabinet fronts(square parts).I use Ardis optimizer and i space the parts away from each other 1mm more then the cutters diameter.
pieces that are larger than 300mm (width/length) turnout 0.3-0.4 mm smaller
then they should.
for example a piece 700mm*200mm
turns out 699.7mm*200m
I will be happy with any idea for asolution.
English is not my native language so plees make it simple.
4/21/15       #2: cnc accurecy ...
John Canary
check your tool diameter-it has to be perfect
4/22/15       #3: cnc accurecy ...
R4G3X Member
It is unlikely that the tool diameter/radius is off since smaller parts are the correct sizes. There are a few other things it could be could you give some more information.
Is it a new/used machine?
If you cut one part #1 299mm and part #2 301mm will #1 turn out to be exactly 299mm and #2 300.7mm? In other words is the error exactly 0.3mm at exactly 300mm length part? And does it matter where on the table the part is located it is always off this much, either in X or Y?
0.3mm error seems almost negligible in the woodworking industry especially for a part 300mm or greater.
4/23/15       #4: cnc accurecy ...
Gilad
Thanks for the replies.
The machine is new .
The problem occurs all over the work table.
I use a straight diamond bit with tow cutters.
the cutter spins at18000rpm.
the optimizer I use sorts the parts:
a part smaller than 400mm in1 of the dimensions will be cut first and at a feed rate of 7meter/min and is cut in 2 depth passes to prevent small parts moving.
big parts are cut at 12meter/min and 1 pass.
I didn't check the exact size were the problem occurs.
I will on Sunday.
4/23/15       #5: cnc accurecy ...
jerry Member
Can you rotate the part so it cuts the 700mmlong the other axis and see if the problem follows or if the 200 mm side is smaller
4/23/15       #6: cnc accurecy ...
Mark T.
Rotating the part is a good test. Also, have you reviewed the actual code at the machine to compare if the numerical code values are accurate? If you are relying on a CAM package this could be a rounding error within the post processor which could grow proportionate to size of the feature.
Mark T.
4/27/15       #8: cnc accurecy ...
GILAD
HI again.
I tried rotating the parts it made no difference.
tool diameter is perfect.
I wold appreciate it if any one cold explain how to check "rounding error within the post process".
Besides that i had ordered a shorter
bit someone suggested me that might help.
THANKS..
4/28/15       #9: cnc accurecy ...
cabinetmaker
Are you common line cutting or actually cutting around the part ? That has hit us a few times.
4/30/15       #10: cnc accurecy ...
Gilad
I cut round the pieces.
I tried a different tool and had the problem was not solved.
I also realized that the problem worsens as the part is longer.
"kabinetmaker" i wold love to know waht was yore solution.
4/30/15       #11: cnc accurecy ...
R4G3X
Since it worsens as the part gets longer its very likely due to rounding in the post processor as Mark T. suggested.
Are you able to program at the machine directly using software that came with the machine? If not maybe have your cnc guy write/modify a program manually to cut a part say 700mm and see what happens. This way if it cuts correctly then you have your answer.
5/4/15       #12: cnc accurecy ...
Tom Galzin
Your machine needs to be calibrated. The calibration process starts by moving your machine a specific amount and then check the movement against a standard. Start by finding the most precise and longest steel scale (ruler) available, 1000 mm or longer. Carefully set the edge of a router at zero, then move the machine 1000mm under program control. Check the result of the movement against the scale. If it's not perfect, the machine needs to be calibrated. Contact the manufactures for instructions how to do it. There may also be local service companies that can do laser calibration, but it may be expensive.
5/4/15       #13: cnc accurecy ...
Gilad
Thanks Tom
I got a tec in the shop yesterday he calibrated the electrical pulses/mm.
The servo engines werent accuretly set up.
It seems the problem has ben solved.
