Subject: Re: 1/8 drill
1/8 drill
5/22/15
Hello,
I am going to start drilling pilot holes for assembly and need to drill a 1/8 hole. Have not really have had to do this on a regular basis. This will be drilling quite a few through holes in 3/4 melamine and plam covered pboard.
Any suggestions on rpm,plunge rate,peck,no peck, bit style and manufacture?
5/22/15       #2: 1/8 drill ...
cabinetmaker
We run the same thing on all unfinished ends whether melamine, mdf or plywood panels for commercial or residential. We just use a 5mm from the drill spindle
5/22/15       #3: 1/8 drill ...
Chris Harmon
Website: http://www.azurecabinets.com
Mike,
For pilot holes I use a 3mm solid carbide bit. Spindle speed is 9000 rpm. Entry speed is 150 ipm. I do not peck drill. It is a waste of time on wood. I get me bits and bit holders from True 32.com I hope this helps.
True32 3 mm Drill Bits
5/22/15       #4: 1/8 drill ...
Kevin Bayerlein Member
Website: http://bayerleinenterprise.com
Chris,
Am I reading you right, 9000 rpm?
Are you using a tool holder and your spindle?
5/22/15       #5: 1/8 drill ...
Chris Harmon
Website: http://azurecabinets.com
Yes, 9000 RPM is correct. Yes, using tool holder and spindle.
You do not have to use the tool holder if you have the right size collet.
View higher quality, full size image (640 X 478)
5/23/15       #6: 1/8 drill ...
JM
We run a 2.5mm drill in the same setup as Chris. We plunge at about 100 ipm and spin at 12000rpm. We do not peck drill.
5/23/15       #7: 1/8 drill ...
Thanks Chris, I just ordered 10, have a collet or adapter for it. I actually think I have a few of them already, but really never used them for a lot of holes. Trying to get set up for CV integration.
5/24/15       #8: 1/8 drill ...
John McGinnis Member
We do the same as cabmaker with the 5mm bit in the boring head. The benefit is that the screw slides in and out freely and doesn't generate any push back on the being screwed through. Much easier than setting up a tool for that too if you have a boring head.
