Subject: Re: m codes
m codes
6/15/15
richard
can any one help me with what this means M244 any help greatly apreciated
6/15/15       #2: m codes ...
Never seen it. I thought anything over M99 was user written.
6/16/15       #3: m codes ...
Brad
It might help if you indicate what machine/control you are running.
6/16/15       #4: m codes ...
richard
thermwood 45 useing profilelab 3D
6/17/15       #5: m codes ...
Think it is a user defined one.
USER DEFINED M-CODES
Details:
If any M-code is used which is not in the above list of built-in codes then the Control Software will attempt to find a file named "Mxx.m1S" in the Macros folder corresponding to the current XML profile name. If it finds the file then it will execute the Visual Basic script program it finds within it.
New macros can be written using an external editor program like Notepad and saved in the Macros folder.
6/17/15       #6: m codes ...
Brad Member
Richard,
An M244 macro on a Thermwood 3 axis machine (such as a CS45) is related to tool changes - in this case putting the previous tool away in the Bar-style tool changer at the rear of the table and then picking up the newly called tool from the "at the head" Typewriter tool changer.
The M244 macro is called by the tool management system (invoke by the PLC) and is NEVER called directly from a NC program.
If you have further questions, I am sure that the folks at Thermwood would be happy to assist you.
Hope this helps.
6/17/15       #7: m codes ...
richard
that would make sense thanks
for the help greatly appreciated
