Subject: Re: aggregate head
aggregate head
8/5/15
Stone Member
I have often thought about getting an aggregate head for my router. I sometimes have a project that requires radius molding, which we normally make templates with the cnc, and then run the molding on shapers. lately, I had a customer who had designed a special air table, in which he needs holes drilled on a 60 degree angle (we are talking lots of holes). Anyway, although I have looked at aggregates on the web, I cannot understand how they work. I mean I see the mechanics of them, but what kind of software does it take to write code for them. For instance, if you were drilling a 60 degree hole, the x or y would need to move at a certain ratio with Z. Is there software out there that calculates that and then writes code for it?
8/5/15       #2: aggregate head ...
I have three types of aggregates. Alphacam produces the code for me. in your example your drawing in Alphacam reflects the proper angle of the hole to be drilled. The code is only correct if the software has data that accurately reflects the length of the tool from the pivot center. It is just simple math. The operator also has to touch the tool off(set length offset) correctly. So, in the end, you put correct info into the software, set up the tool accurately, and you are all set.
8/6/15       #3: aggregate head ...
Mark T
What are the dimensions of the table? An alternative method would be to make an inclined vacuum jig to tilt the table and use standard tooling. This would only work if the piece to be machined is narrow enough, that on the incline it still clears your gantry or cantilever. Definitely cheaper if its a one off.
You are correct on the basics of the code, most cam packages and a lot of conversational controls on the market will generate the correct code for aggregate applications.
Hope this helps
Mark T
