Subject: Re: furniture parts CNC service needed NY area
9/27/15
NY Furniture Design
hi,
we looking for a woodworking shop in the NY/NYC area to outscore cnc work for our cabinet parts. Most parts a made from veneered MDF and edge glued solid wood panels. We supply all materials and drawings for parts, CNC machining is needed for cam and dowel connection, machine to size, profiling, dado/grooving and 45 miter.
we would prefer to work with a shop using a Weeke, Biesse, Homag or Holzher CNC center.
9/27/15       #2: furniture parts CNC service needed ...
Leland Thomasset  Member
Hello I saw your post in the cnc forum. We run a 5x10 Omnitech /Anderson CNC If you would like to provide a sample drawing I can provide a proposal.
9/27/15       #3: furniture parts CNC service needed ...
I did not mention our location we are located in Pawling NY about 15 miles north of Brewster
9/28/15       #4: furniture parts CNC service needed ...
Chad
We are located in central PA. We have Weeke and Homag routers including 2 BAZ's. We also have software (CADCode) that can read MPR files, and create code for any other brand of machine.
9/28/15       #5: furniture parts CNC service needed ...
Rich  Member
We have 2 panel saws, 2 banders, 2 morbidelli PTP, 1 Biesse BreMa Eko 902 (verticle machine center), and a Ganomate drill/Dowel inserter (with verticle head for RTA). Also have a PVA laminating line (for HPL laminates only no veneer).
We are located in north east NJ between the GW and TZ bridges. We are mainly a laminate shop but do use some veneered panels.
9/28/15       #6: furniture parts CNC service needed ...
Chad Romig  Member
Website: http://www.northwayind.com
We have 2 panel saws (Schelling, Holzma), 6 edgebanders (Homag, IMA, Biesse), 2 Northwood Ironhorse 510's, 1 Homag BOF 311, 1 Weeke Vantage 200, 2 multiple spindle Heians, 1 Multiple spindle Komo, 1 Heian PTP, 1 Weeke BHC 550, 1 Weeke BHX 500, 1 Homag BAZ 322, 1 Homag BMG 512, 1 Homag BAK, 4 Accusystems dowel inserters, Heated Midwest PVA Press line, 2 Dakota Automation Inventory Systems, CADCode, Cabinet Vision, TopSolidWood, Ardis, and Cutrite, in house built on-line cabinet ordering system, with a new version about to be released. But who is counting.
