Subject: Re: Good bit for flat bottom fills ?
10/7/15
B.H. Davis  Member
Website: http://www.curvedmouldings.com
I'm wondering what others have found to be the best bit for as swirl free as possible large fill area. By fill area I mean a recessed area where the entire bottom surface was milled down to a finished and exposed surface.
This would be for a situation where the bottom cutting edge on the bit is more important than the side cutting edge.
The fill areas can be a few inches square or larger.
I've got a 2" diameter bit with carbide slips inserted into the bottom face that does a decent job on larger areas. But I'd like something in a 1/2" diameter bit for smaller jobs.
Thanks for your suggestions.
