Subject: Re: Laying out radius
Laying out radius
12/30/15
Gavin s
Website: http://soraghanconst@sbcglobal.net
Hey everyone , I need to replicate some arch top doors . They are not a true radius they are more of an ellipse . I know how to replicate radius' by hand but does any one have a trick or remedy to mimic this in cad ? I'm using alphacam and biesse works .
Thanks everyone
1/1/16       #2: Laying out radius ...
B.H. Davis  Member
Website: http://www.curvedmouldings.com
You need a template tracing of the existing shape. Then you can digitize that into AutoCAD.
No digitizing board? Not a problem. Put a laser pointer on your CNC Z-axis and the template on the table. Move the Z-axis around the table so that you can select points every 3" to 4" along the template line. Record these points and then type them into AutoCAD while creating a SPLINE.
Works perfectly although a bit time consuming. Years ago when we were doing it this way a lot we would speak the points into a tape recorder for playback when entering the data into AutoCAD. Then we got our 44" x 60" digitizing board and got rid of the tape recorder.
2/5/16       #3: Laying out radius ...
JOHN
best way is to just measure up some reference points and replicate it in cad. don't know why you would use a cnc with a laser when a tape measure and square will do. the closer your points the more accurate your curve will be. the smaller the radius the closer the points.
