Subject: Re: Biesse Rover K1532 Pendular machining in origin 5 & 8 help
2/5/16
Tony Member
Biesse Rover K1532, during Pendular machining in origin 5 & 8 help.
1. I am working with cabinet boring, so have to make mirror ( left right legs) panels.
2. I will start working from origin 5, cycle starts and boring will start at origin5
3. I will press origin 8 start button. Stopper will come up
4. I will start button again for photocell booking. Machine will switch to slow mode.
5. I will enter at origin8 and fix workpiece.
6. I will press photocell reset button on pod rail , and press start button after coming outside photocell barrier. Stopper rods will go down.
7. But the photocell not gets reset, still machine in slow mode "error photocell engagement booking performed".
8. To reset photocell fully and to run machine at normal speed, I have to press photocell reset button on pod rail and start button
9. After 4 th cycle start button also not work (stopper rods will not come up) . this happens simultaneously at each origins at every 4 th cycle.
Please helps
Regards,
Tony John
2/6/16       #2: Biesse Rover K1532 Pendular machini ...
tony Member
solved , by using worklist
