Subject: Re: Nesting veneered MDF panels for 5 piece cabinet doors
3/19/16
SB Member
Does anyone here nest the center panels for their 5 piece wood cabinet doors instead of cutting on a table saw? Wondering if this would be a good idea with my new nesting table.
3/20/16       #2: Nesting veneered MDF panels for 5 p ...
Depends.
Cutting them on the TS is likely quicker and will yield better.
But if you are a one man or a low man shop then while the CNC is doing the panel cutting you can be doing something else.
3/22/16       #3: Nesting veneered MDF panels for 5 p ...
Salce Smith
Website: http://www.ricocnc.com/
Hi, nest cutting them on a cnc router is recommended. Save time and maximum use the panels, production optimization.
3/23/16       #4: Nesting veneered MDF panels for 5 p ...
Gary B.
SB,
If you have an automated way to create the nest code, I'd do that. I'd also run a small diameter bit for those panels, 3/8" or even 1/4" would be fine, to help with yield if necessary. I think it would be faster than a table saw as long as you didn't have to program it.
5/3/16       #5: Nesting veneered MDF panels for 5 p ...
Joe
I nest them all day. I have a program I could give you that I wrote. will make your cutlists and give you nested sheets or dxfs from a CSV file.
