Subject: Re: Cnc advice
Cnc advice
4/20/16
Patrick Member
Hi,
I am looking for honest independant advice in Ireland on buying a Cnc flat bed router. I have a small shop which is in need of one. It would be poss 12 to 18 mths before in a position to buy. I would like to talk to someone with a lot of knowledge on the subject.
I would like a flatbed nesting Cnc with ATC, at least 6/8 drill heads in the x and y axis, horizontal boring,either a C axis or facility to add one later and a slider to push/ drag pieces from the table.
I have to many questions but here is a few pointers.
1. Is it possible to buy an older machine and update the Pc side of things, circa say 2000/2004.
2. Lots of global websites out there, risks importing used from US, CAN, AUS, one benefit I suppose is no Vat. Still digging our way out of the **** so funds are tight, can't afford new,v limited examples here, UK sterling prohibitive, what are the pro's/ cons of buying from these sites if I employed one of you guys to advise and poss travel to see/check out a running Cnc in Europe or further a field. Today for example I saw a 2013 biesse skil in CAN for around 40k so in my head with shipping, install etc say around 50k. This is still 25k cheaper than here for new which is huge.
I don't want to spend 50k but it's just an example.
3. Vacuum pumps, what size to suit nesting
4. Extraction, would a 3 or 4 bag do for a few months until I could get another few bob together.
Small shop so I'd say it would only be running maybe 2 days a week at start.
5. What brands to consider and stay away from.
6. Bed size, mostly 8X4 sheets but should I consider larger bed for say 10x4,10x6, and say worktop cut outs etc.
Think that's enough for the minute.
Any and all advice greatly appreciated
5/3/16       #3: Cnc advice ...
Joe
Some machine vendors can point you toward businesses that they know are about to go under - or are needing to unload a machine. As for what you're looking for: we picked up a used SCM universal 20 with load/unload and 2 seats of alphacam (1 year old on all) for 60k$. Not the deal of a lifetime, but not a bad price either. It had minimal (2 hours tops) use.
8/18/16       #5: Cnc advice ...
James Hill Member
ou can look for CNC mills for this work. CNC mills operate in torque. CNC mill cuts efficiently so provide accurate results. It can be used for wood cutting as well as metal cutting in metal printing process. You can check here for CNC mills.
check here
