Subject: Re: Cnc Router Bits
Cnc Router Bits
5/23/16
anthony Member
Hello all
Hope your having a great day
I would like to ask you what types of bits that i "Must" have to start working with my cnc
knowing that i will be cutting melamine and mdf ... and will be working with hard wood like creating hols for door lock cylinderss ...
5/23/16       #2: Cnc Router Bits ...
Chuck Hicks  Member
Compression Bits or up/down cut bits would be a great place to start. 2+2, then the choice would be the diameter and cutting length that you need.
5/23/16       #3: Cnc Router Bits ...
anthony Member
Thank you Chuck Hicks for your tips
i would like to know the 2+2 is the Spoilboard Surfacing bit ? if yes can it be used for hard wood ?
5/23/16       #4: Cnc Router Bits ...
Chuck Hicks  Member
Anthony,
No, the 2+2 is the compression bit. The 2+2 means two flutes down and two flutes up. Now we have a Insert spoil board cutter also that works great. It may be best at this point to just give us a call if you can. 877-465-7012
5/23/16       #5: Cnc Router Bits ...
Gerry
We use .5" compression cutters for outline and .25" down-shear for grooving. I agree on the insert spoil board surfacer it is the way to go. Some people use the .375" compression for outline but we have always used .5".
If you have a good supplier near by you can just get them as the jobs require.
6/16/16       #6: Cnc Router Bits ...
Spoil board tool, 4" with 4, C6 inserts. Panel cutting, Onsrud Marathon coated, 3/8" 2 flute, compression, 16000 rpm @ 600". Other bits as needed. Pocketing with down spirals. Aluminum cutting with end mills. Some grades of aluminum are sticky and require fluids.
