Subject: Re: multicam scanner
multicam scanner
6/2/16
CHAD Member
we have a multicam 3000 cnc router and purchased a scanner from them. When we received it we were planning to scan Cabinet Vision s2m nesting sheet bar codes. We called Multicam and they told us we would have to print there bar codes off to get it to work. Anybody else run into this?
6/7/16       #2: multicam scanner ...
Joe
Typically a barcode scanner will emulate a keyboard. The code on the page should match a program on the machine. Not sure of the interface on the multicam's but on Morbidelli and Homag I've had no problem programming the scanner to feed "open program" or (shift+f2) to the machine and then input the name of the program.
