Subject: Re: SCM Routech 210 AL issues
7/11/16
James Miller Member
A while ago, i posted about some calibration issues. I have since fixed those. Now I am having an issue where I'm getting an error message that says "head 2 not in position" every time the program switches to use a different tool. Head 2 is the boring box that is fixed to the spindle and uses the same z axis. Anyone familiar with this? Trying to avoid a 5k tech visit for something that seems minor.
The last few sheets I ran didn't require any boring and the following sheet didn't either but produced the error. Tried running the previous program and got the same results.
Any help is greatly appreciated.
7/11/16       #2: SCM Routech 210 AL issues ...
Sounds like a proximity switch is not satisfied. Typically a light on the switch is illuminated when it is seeing the drill head in the up position. See is anything is impeding full movement of the drill head. If not, try slightly re-position the switch to a place where it is activated.
7/11/16       #3: SCM Routech 210 AL issues ...
James Miller Member
Good point. I'll see if I can find one. I've had this machine for 18 months now and I'm still trying to figure out everything. Thanks so much.
7/13/16       #4: SCM Routech 210 AL issues ...
Zach
Website: http://deasmillwork.com
even though the boring head is on the same z axis carrage as head 1 it has a puenmatic cylinder that actuates it in and out of position. The cylinder has a magnetic sensor for the up and down positions. The cylinder may be leaking air and letting the head drop out of position of the sensor may be out of adjustment. Both are easy fixes.
