Subject: Re: CNC Drill Head Lubrication
8/19/16
Hi and thanks for any advice.
At work on a Andi Genesis Evo 49, the grease for lubricating the rack was incorrectly used to lubricate the drill head. It was then pumped through incorrectly with drill head grease for a Andi Selexx CNC.
Is it going to be a serious problem or can the correct grease be simply pumped through.
8/29/16       #2: CNC Drill Head Lubrication ...
What kind of grease did you put in it? is it remotely close in makeup to the stuff that is supposed to be in it? I think that if you pump the correct grease through that you will have no issues.
I have a SCM and in the manual there is a whole list of grease types and manufacturers that are listed that you can use for the machine, but the dealer insists that you have to use the stuff that he sells that is a million dollars a tube, I think it is a big scam, but because I don't use a lot, I use the million dollar stuff and then make fun of myself for being so gullible.
8/30/16       #3: CNC Drill Head Lubrication ...
Mike and Scott,
There is a reason the dealer said that. I once bought what was supposed to be a compatible grease from an oil, grease company. It would have worked just fine all by itself, but the problem occurred when the two mixed and formed waxy plugs in my SCM autolube system. All of the rails got dry before we noticed no grease was moving. Took a few days and a lot of manual labor for the operator to completely purge the system and put everything back together.
Mike, I have had a couple of drill heads go bad over the years. I don't suggest trying to take them apart unless you are a real good mechanic. A soft start might be helpful and extend the life for when the grease is cold.
