Subject: Re: Texture Panels, MDF, and Sanding
9/2/16
MarkB Member
Running a bunch of panels that are going to be sprayed with pigmented CV. Im sure Im not the first one to think of this but wondering about milling them a few thou over and then sealing them heavy
to saturate the MDF then back on the CNC for final (or even perhaps twice)?
9/3/16       #3: Texture Panels, MDF, and Sanding ...
james mcgrew Member
Basically there is no reason you could not do this, just get the rergistration of the panel correct,, please post your results
View higher quality, full size image (1024 X 681)
View higher quality, full size image (800 X 534)
9/3/16       #4: Texture Panels, MDF, and Sanding ...
Zach Froble  Member
Website: http://www.lyndandesigns.com
James,
What software are you using to create those panels?
9/3/16       #5: Texture Panels, MDF, and Sanding ...
james mcgrew Member
Aspire by Vectric, although these could be done in Vcarvepro
9/3/16       #6: Texture Panels, MDF, and Sanding ...
james mcgrew Member
Here is a recent make over for a hotel that had to refit is desk but replacement and timing were not feasable
9/3/16       #7: Texture Panels, MDF, and Sanding ...
Thanks James,
Your panels are definitely something to aspire to (no pun intended). We dont work with MDF much (I always felt the stuff was invented in purgatory) and Im going to run these couple with some brazed tooling (1.5" Ball Nose) that I already have so Im sure the MDF is going to be shaggy to say the least. I'll give it a go sealing the surface and then a final cleanup pass and see what happens. Was just wondering if it'd be worth it or not.
9/3/16       #8: Texture Panels, MDF, and Sanding ...
james mcgrew Member
cut one file at say .23 deep (if you are wanting .25) spray a coat of sanding sealer on it let dry, then run another at . 02 starting at .23.
time consuming but i got 7250.00 for repaneling that desk. remember it was a panic job 250 miles away
9/3/16       #9: Texture Panels, MDF, and Sanding ...
james mcgrew Member
and all of the deep profiles i have shown were done with 2" ball nose bits, geometrics are profiles and pockets.
also we use HDF panel not mdf.
9/3/16       #10: Texture Panels, MDF, and Sanding ...
james mcgrew Member
Mdf can be a miracle product if sealed correctly. the players are full size 24" deep machined in 3" layers and glued together using the slicing method
9/4/16       #11: Texture Panels, MDF, and Sanding ...
Thanks James,
I have some HDF on my next truck so we will see. The sealing on the MDF isnt looking to be too advantageous but still playing around.
