Subject: Re: BiesseWorks lead-in lead-out
11/19/16
Shawn Lalande Member
Website: http://synergykitchens.com
We recently purchased a Biesse nesting machine and we have come across an unexpected situation regarding lead-ins.
We do our designs in Mozaik which out-puts a cix. file for Biesse Works. There is no lead-ins or outs specified by Mozaik.
Up until now the default lead-in the tech who set up the machine set in Biesse Works has been fine but we are getting into some machining that does not require lead in. My question is how is the default set and is there a way to set defaults per tool, route type or what ever so that when a cix file is brought in it defines the lead-in by tool.
11/19/16       #2: BiesseWorks lead-in lead-out ...
Dan
The defaults are set on the 'milling data' tab in Settings.
You can set a tool class or specific tool for milling with default lead-in values, etc.
I didn't see a way to attach the value to a tool.
Don't know how much of it you need to do but once in a while might be done in a cix post with notepad by adding the parameters and values.
11/19/16       #3: BiesseWorks lead-in lead-out ...
Shawn lalande Member
I have been trying that in settings under millings but does not seem to affect anything when opening the cix file. Not sure at this point where the default lead-in is coming from.
11/20/16       #4: BiesseWorks lead-in lead-out ...
Dan
Start a simple panel in BW
Go to settings and change a lead in, click the check to save.
Look at the milling window and the milling from geometry and see if the setting has changed. Try it again to see that the default is changing when you change the setting.
Then
Have a look at a cix post for a simple rectangle in notepad. If the macro (ROUT or ROUTG) does not contain param,name=
TIN
TOU
AIN
AOU
The default lead (in-out) you set should be picked up when you open or import the cix.
If You are doing something that has more than one milling operation and more than one lead strategy you need to this in the cix.
I don't use Mosaik but understand the Mosaik post is open source? You should be able to edit it and assign "tool based" leads there.
11/21/16       #5: BiesseWorks lead-in lead-out ...
Great advice Dan thank you
Have been told multiple time lead ins, lead outs are handled by Biesse Works.
Does not seem to be the case as they are in the cix file as can be seen in included jpeg
Only choice modify cix in notepad PITA
as ramp in is unchecked in Mozaik and this is the file I am getting
View higher quality, full size image (970 X 735)
11/21/16       #6: BiesseWorks lead-in lead-out ...
Wood Dust
This is an issue with your post. Biesse works does not modify the CIX file you send to it.
You will have to ask whoever wrote your post (biesse or mozaik) to tweak this issue for you.
5/3/25       #8: BiesseWorks lead-in lead-out ...
Steve Member
I've run into the same issue with Mozaik and BiesseWorks—default leads not behaving as expected. Editing the CIX in Notepad is definitely a pain. It would be great if Mozaik gave finer control over that output. For smoother integration between CAM and operations, I’ve been testing some workflow automation tools like Phonexa—surprisingly adaptable even outside their core industry.
5/4/25       #9: BiesseWorks lead-in lead-out ...
Dan
Yes, it won't change a 0 value in that field as 0 is valid. 0=None
Not familiar with Mosaic. Does it not have a spot in the program to change leads to send to post?
Site shows ( Enter custom CNC tooling, control all parameters) in the CNC version?
